Hey everyone,
I am about to upgrade my HTPC which i've had for 4 or 5 years so it's not exactly super speedy (although pretty good) but mostly the cpu fan is incredibly loud. It's in an Antec NSK2480 case which I quite like so was thinking about just upgrading the motherboard/cpu/ram. Currently I have an abit fatality F-190HD with a Intel Core 2 Duo 6320 @ 1.86ghz processor (with standard fan). I'm currently running Media Center on Vista with an extender which I like and was going to upgrade to Win 7 MCE which looks much better.
I was thinking about a Asus P8Z68-M Pro Intel Z68 (http://www.novatech.co.uk/novatech/specpage.html?ASU-Z68MP) or an Asus P8P67-M PRO Intel P67 (http://www.novatech.co.uk/novatech/specpage.html?ASU-P67MPB) with an i3 processor. These motherboards have hdmi on board so one question is will this be okay for HD output for blueray or downloaded HD content with an i3 or do I really need a separate graphics card? Additionally one of the main things I want is a quiet HTPC so was looking at the following coolers, i think the Scythe may be best as i'm worried the others won't fit in my case:
Zalman CNPS10X QUIET CPU Cooler (http://www.novatech.co.uk/novatech/prods/components/cooling/cpucoolers/zalman/cnps10xquiet.html)
Zalman CNPS5X Quiet Compact Tower CPU Cooler (http://www.novatech.co.uk/novatech/prods/components/cooling/cpucoolers/zalman/8809213762109.html)
Coolermaster Hyper 212 Plus CPU Cooler (http://www.novatech.co.uk/novatech/...g/cpucoolers/coolermaster/rr-b10-212p-gp.html)
Scythe Shuriken Rev.B Quiet Low Profile CPU Cooler (http://www.novatech.co.uk/novatech/prods/components/cooling/cpucoolers/scythe/scsk-1100.html)
I was then thinking of getting 2 x 3TB of the WD Green SCSI drives (http://www.overclockers.co.uk/showproduct.php?prodid=HD-376-WD&tool=3) and use the RAID controller on the motherboard to mirror them so if either fail then i can just switch to the other and get a replacement. Sorry for the ridiculously long post but my questions are:
1) Does the mobo/cpu combo sound like a sensible choice and will the onboard HDMI suffice?
2) What do you think of the coolers i mentioned or are there any others i should consider given noise is the main factor?
3) Are there any better 3TB (or possibly 2TB) drives in terms of reliability, noise and cost (as this is all more expensive than i can really afford anyway!)
4) Are there any particularly good 3 or 4 bay NAS enclosures that i could use instead, as i quite like the idea of a NAS but if it's going to be much more expensive i might as well just have 2 big drives in my pc.
5) Are there any other general suggestions in terms of setup that you have?
6) I have a NOVA-T500 pcie dual tuner card i'm using now which i intend to move into my new system. I'd ideally like 4 tuners for freeview so was going to get another dual card/usb (would prefer internal if possible). Ideally i'd also like to pick up Freeview HD. Do you have any recommendations as to a good additional tuner card to get?
Thanks so much for your help guys, sorry for the crazily long post!!
Dave
Dave
