cjreis said:I just realized that the abit TH7II is made for 400MHz fsb and the 2.26GHz proc. uses 533MHz fsb.
cjreis said:Thanks for the tips on the sound card. Are there any chips (P4) that would require less FSB and still have a good chance of 3GHz? If not I will go for the same and go as high as I can.
Edit: I am going to get the Swiftech (I frogot the name) with the 84cfm vantec tornado. For PCI: Modem, Sound Card, Video Capture Card. Video Card is a Chaintech GForce 4 Ti 4600. Case is a Antec with six bays and 400 watt power supply Mutlple case fans that result in a slightley positive case pressure and a reobus to quiet the fans (always important).
About the memory I am still confused as how to run it when the mobo says it's only supports PC 2700 not PC3000. Any help would be great and thanks for all of the help that you gave me.
Darryl_D said:
Now for the 2.26b the reason why people are getting it to 3ghz is because DMI was wrong! It has a multiplier of 17 not 19!!! and so this is how 17*133=2261... hence 2.26...
overclocks waaaaaay better than the 1.8a but just a little less than the 1.6a
