cjreis said:
It would be almost imposible because the maximum FSB on the ASUS with resonable PCI speeds is 150FSB. To get to 3.0GHz with the 2.26 it would be 17x(mutliplier) x 177(FSB) = 3.009GHz. As you see that could only hapen with no PCI cards instaled. Now people Have been hitting 3.0GHz with the Abit BD7-II because of locked PCI or dividers (I can't remember which one).
On P4S533 you won't reach 177MHz FSB no matter how hard you try. I believe the BIOS limit is 166-170.
Yet I was able to run it quite stabnle @ 150MHz bus with 1.8A, t.e. @ 2.7 GHZ (3DMark2001SE won't work, prolly bekuz of too high AGP bus).
So in theory 2.0A should reach 3GHz at 150MHz system bus.
Yet I had too decrease bus due to 3DMark2001SE certification to 148MHz. And after that OpenGL start complaining. Games such as Medal Of Honor Allied Assault and others written in OpenGL were crushed randomly until I backed up to 146MHz bus.
Note, that I have a lot of peripheral cards/devices installed:
Onboard LAN
Leadtek GeForce4 Ti4400
Broadway Video Capture PCI
USRobotics 56K Modem (for backup dialup, I am on DSL)
SoundBlaster Audigy Platinum Ex
So all of them together might limit PCI/AGP top frequencies.
On P4S533 which imo is simply the best board out there (save for RDRAM PC1066 boards, where you have to put about $300 more for a couple of procentage points advantage in mem benchmars).
Yet, when I experimented with stock fan, at 2.7GHz 150x18 on STOCK FAN I was getting up to 60*C CPU temp (with amb temp about 28*C, or 82*F).
Latest Alpha and (of course) Swiftech will bring it down to 50*C and below.
BTW all of those 3GHz+ system are watercooled, and remember that there is a luck involved in hitting those results. Yet as I know, most of those guys backing up a lot to do the normal computing/gaming.
