- Nov 13, 2001
- Chicago.
Hi there,
I am currently weighing delidding my 7820X in order to replace the thermal compound that Intel put there (as they use compound instead of solder on the Skylake-X for whatever reason).
If I were to go through with this (and I'm not sure I will), what would be the best compound to use?
* Conductonaut - 73 W/mK. Some people have reported that it breaks down over time? Should be safe, I'd presume, between the core and the IHS which is nickel-plated copper (I presume).
* Kryonaut - 12.5 W/mK. Obviously far less thermally conductive than Conductonaut. Still likely far better than the stuff Intel put in there.
* Fujipoly XR-m Thermal Pad - 17 W/mK. Better than Kryonaut, surprisingly, but also 0.5mm thick. I suspect that since it stays solid, it would likely insulate the core and would make temperatures worse.
* SnAg Solder - 78 W/mK. I have no idea how you'd solder it without damaging it.
* Indium 100Au - 318 W/mK. Available as a foil, possibly thin enough to use as a TIM? Ridiculously high thermal conductivity.
* Indium Pure Indium - 86 W/mK. I think this is what Intel uses. Not sure how you'd use it without damaging it.
