- Aug 6, 2011
- Hot place
Hello all!
Figured I'd post up some stuff I'm tinkering with at the moment. Here is a BFG of off Flee bay got for about $18.00 with shipping, I opened it up first thing as it was FULL of dust bunnies. Then I removed the main board screws as none of the CAPS seemed to be swelled up or leaking, and boom burnt traces underneath the board. Problem is now I don't even know this parts name?
Here' is my history for you all to see so you know I'm a noob to this stuff, I have worked as a Slot Technician for the past eight years, mostly part swapping. But I always love to open stuff up, as if its blown anyway why not not right? I've worked as a mechanic, ETC. I was planing on maybe doing a CAP job on it, spank it on the *** and use it for a friends build. Here in full glory are da picture's, again assume nothing as I don't know what that four pin part is, but I have learned enough to know that simply replacing it is asking for trouble too........
OH and I do have a new soldering iron with several tips for it, some de-solder and such. I'm running right now on a ACER X223W that I got for $40.00 off of Flee bay I planed on fixing, turns out it was a stuck button and will do nothing while the button is "stuck" such as power on
Thanks guys!
Thanks guys!
