bios 3507 dimm voltage?
EspElement
how come on this bios, i cant change the ****ing voltage on my memory. Why is this? Its set to auto, when i try changing it my cmos locks, and i cant do anything so i press ctrl,alt,del. I dont get it, i got Geil 3500, that i wanna try running at 466, but i cant raise the volts to get it to work. Anyone get this problem? Should i reflash this bios?
E
EspElement
guess im just gonna reflash the old bios 3402, since no one wants to respond. thanx for all your help....lol
gogetadbl
Yes a lot of people have been reporting this problem. seems first you have to set it to optimized defaults then do it. But i would stick with 3402...
eliteoneXP
All you have to do is select load optimate settings then save changes. The dimm settings will come back.
