Dad00
- Jul 15, 2015
- Fox River Valley, Wisconsin
I am building my first water cooled computer. To minimize corrosion due to dissimilar metals I want to build with mostly copper and brass. I want to minimize or eliminate Nickel. From the Bitspower Online store in Taiwan, you can get a description of each True Brass fitting. Some fittings such as the 1/2 inch Barb are described as "Hi Quality Brass Material" with no mention of a finish as they appear to be just a bare brass fitting. Other fittings are described as "High durability True Brass Finish", and other fittings are described as "High durability Nickel Finish in True Brass Color".
From people who have bought these "True Brass" fittings, are the Bitspower Online store descriptions accurate? Is there Nickel in the "High durability True Brass Finish"? From people who have used these fittings in their "Distilled Water + Silver" only systems have you had any corrosion from any of the Bitspower True Brass fittings, and if so, what finish did the fitting have on it?
