Straggling in Late once again on a post
(Hey I got a new boat that I am putting a new floor in ATM (Well new for me its actually a Very old boat that I took in to restore. It's a classic. Some people do car restoration. I do boats and computers. But I enjoy water with both
you can also get a Paypal account without a credit card AFAIK, you just need a bank account.
Statement is true. You do not even have to have a checking account. Just a savings that allows electronic deposits. (This is the way I did it.)
i went with the GT, because sadly, its the best cpu waterblock that my local shop will bring in for me. if i find that temperatures arent quite what im hoping for, i'll be getting myself a prepaid credit card, and ordering a better one for myself online.
BTW all it takes to get the prepaid is about $8 and a trip to Walmart for their Walmart money card you actually just pull from a shelf, Buy and load with cash
NOW: On to the main issue:
If your local shop will not get what you want, Buy it online. In the "Old days" Buying online was risky, But with reputable dealers like Petras, Newegg, FrozenCPU, etc, There is no reason to cut corners because your Local shop isn't up to par.
Anyhow people are correct. The Apogee GT is outdated and not worth getting IMO, Take the time to review blocks, and get the one best for you. Also take into consideration whether your CPU IS Lapped currently or if you are planing to do so in the future. The Apogee GT will be worse than air cooling if you Lap your CPU, the GTZ isn't as bad on Lapped CPU's cause of the new mounting system. But others are better.
Some nice CPU Water block reviews I have found are :
If using an UNLAPPED Stock Processor:
http://vapor.skinneelabs.com/i7/Round1/Round1i7.html
If you have a Lapped or are planning to Lap your CPU: (Which IMO helps SO Much I dropped 18c under full load)
here is a nice review with lapped processors. (Note comment #11)
http://www.xtremesystems.org/forums/showthread.php?t=224976&highlight=heatkiller
However it seems you have your items, and have it up and running.
10c Hotter than the Aircooling. something is wrong. Air in the line, or (Is your CPU Lapped?) if not maybe check the mounting.
I want to clarify for myself. What is your EXACT Loop. What is being cooled with this setup?
If you have just your CPU in this setup with a 3x120 rad and no other blocks, 41 CFM fans should still get you better cooling than you had on air as long as you have all 3 installed and running and your CPU is not lapped. Even with the after market Thermalright Ultra-120 eXtreme, Any watercooling setup should never run 10c hotter.
Just so you do not think I am a rookie blowing smoke (I know how to research)
http://www.evga.com/forums/tm.asp?m=100819358
Note the comment by XLAR8 Post #3 to be exact. He is correct that radiator works better with lower CFM fans actualy, as by design.
Just Note, THAT is your exact CPU in his comment. (Yes he is only at 4GhZ not 4.5GhZ) But still its a nice find for your situation.
