- Sep 7, 2010
- California
Hello!
I'm not sure on where to go about this. I've never had to ask for help, I have always been able to research and troubleshoot my issues, but I just cannot figure out what is wrong with my computer.
I will list my specs at the end.
My Issue: I turn on my computer and nothing is displayed on my monitor.
When I turn on the computer all Fans and LEDs are on. Hard Drive Activity light works. Disk drive can open and close. No beep codes. Graphics card fan spins.
I have checked all wires to make sure they are connected properly and in the right places.
I have taken my RAM out and tried it in another system, the RAM had no problems.
I have tried other graphics cards: Nvidia 8400 GS, Nvidia 7300 GS, ATI HD 3870 HIS.
Backround info: This computer was built in 2007-2008ish. I did not have any problems when I first built it. Few months down the road though, the computer would NEVER turn on the first time. The lights and fans, everything would turn on BUT no display. I always had to turn it off, then back on to get it to display. Once it was on it worked perfectly fine.
Another thing: When I turned on my computer my FAN speeds would start off at 100% then drop to automatic.
Zooming up to the present, of yesterday. I was doing my monthly maintenance on my systems, dusting and cord managing. I wanted to prepare my computer for when I put in a new heat sink and new RAM.
After I plugged everything back in, I went to turn it on but nothing happened. I made sure the switch on the back was switched but still nothing. Then I realized that my Motherboard power light was not on. Great, so I took a 450w PSU from another one of my systems to see if it was my PSU or my Mobo just died.
It ended up being the PSU, the light shined bright green when I plugged in my 450W PSU.
So I took out the PSU, quickly drove the Best buy to grab me a new PSU and to just go ahead and get the new cooler for my processor.
I picked out an 850w Thermaltake PSU, and avoided the Rocket fish ones... (The rocketfish PSU is the one that died, and I think is what was causing me problems)
The Cooler I got was the Corsair H50
I Got home plugged the new PSU into the motherboard and sure enough, the green light was glowing brighter than ever before.
After than I went ahead and hooked up the Corsair H50, it was a little cramped in my case but it fit.
So NOW I went to turn on my system, it turned on just fine, the H50 was running, I could feel the liquid moving, the fans were spinning. everything was plugged into the right places. GPU was plugged in to PSU and connected to the first PCI E slot.
but NO DISPLAY
Nothing, what so ever.
My monitor detects that it is being plugged into something, it works on other computers. but nothing is being displayed from this computer. Not even a beep code.
Here are my specs:
Case: Antec 900
Motherboard: Asus M3A32mvp-Deluxe/wifi
RAM: 4gb, 667 MHz 5-5-5-15 (Not the standard, which is why I wanted to get new RAM)
CPU:AMD Phenom II x4 940 3.0 Ghz
GPU: ATI HD 4870 HIS
Sound: Creative Soundblaster Fatal1ty pro series.
Hard Drives: Raptor 150gb, WD 320GB
Standard DVD RW lightscribe Disk drive.
Power Supply: Black Widow Thermaltake 850w
And now with a Corsair H50 cooler.
I think it may just be my motherboard... maybe a part of it broke while I was cleaning it or something? I am always sure to be grounded. I have the wrist strap.
Help/thoughts/ideas would be greatly appreciated
but NO DISPLAY
Here are my specs:
Case: Antec 900
