Hello,
I have the famous SOYO-TISU i815Ep B-stepping. the SOYO-TISU is famous for having a bug in the bios that while tualatin pentium 3's can oc', the SOYO-TISU does not allow the celeron tualatin to OC'. you get an "CMOS ERROR DEFAULT LOADED." and the default ROM bios settings are loaded. SOYO TISU only allows the celeron tualatin FSB to be set at 100mhz.
There are two closely related solutions to the problem.
according to
www.kilowattalley.com/easy
there is a recommendation to disable BOTH BSEL 0 and BSEL 1
(i.e breaking off pins)
whereas
http://www.ocforums.com/archive/thread/139551-1.html
disabling ONLY BSEL 1.
Both agree on disabling BSEL 1. which leads to the obvious question,
What does BSEL 0 pin do?
What does disabling BOTH BSEL 0 and BSEL 1 do that disabling
BSEL 1 only fails to do?
I've contacted both overclockers and kilowattalley but with no response. of course SOYO recommends you don't overclock.
If others post follow-ups, i will post my "results" based on their recommendations.
according to
whereas
