- Jun 29, 2010
Building my first rig. Am I doin it rite?
I've been reading up on Computers for quite a bit these past few days. I know more than your average Joe, but when we get down to it...I'm a guppy in the lake. I've read, watched, and absorbed a lot of info in my quest for a cheap (Under 1k) gaming rig. Here's hoping that your expertise can supplement my basic knowledge and create something wonderful.
I have speakers and a monitor (24 inch, 2ms, 1080p for $160!) I'm going to be using this computer for gaming. School, movies, interwebs, but the main focus is gaming. World of Warcraft and Starcraft 2 primarily (I have a 360, so no FPS most likely). I will try to overclock, after reading about computers I've come to the conclusion that it would be criminal not to overclock. Here is what I'm looking at. If I forgot anything or you have questions, PLEASE ask. I'm trying to get the most bang for my buck and if you see any discrepancies I will be HAPPY to look like an idiot.
Case: NZXT Apollo Black
Seems like a good case, reviews say decent size and it looks rather sexy and is cheap. Suggested by a friend.
CPU: Intel Core i5-750 2.66GHz 4 Cores or AMD Phenom II X3 720 Black Edition 2.8GHz AM3 3 Cores
The AMD seems to be the best budget buy and after hearing so many good things about AMB (it can generally do most everything an Intel can for cheaper) I was interested. Then I heard how stupidly good you can get an i5 if you overclock it. Since I plan on overclocking, the i5 sounded damn sexy at that moment. Leaning toward the i5, but not sure which to choose.
PSU: CORSAIR CMPSU-650TX 650W
I read the how to build a computer sticky which confirmed my belief in Corsair being a great brand. Reading the reviews on this makes me think this is a great PSU for my price and power range.
Mobo: EDIT: Going with ASUS P7P55D-E LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard Supports DDR3 and looks pretty solid.
RAM: I plan on overclocking so the building a computer sticky suggested a 1600Mhz DDR3. I'll most likely go Dual Channel since I've read Triple Channel is designed for Intel's i7 and since I'm most likely getting an i5. I might be wrong though, feel free to correct and suggest.
EDIT: Going with G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL DDR3 and has good reviews.
Hard Drive: Western Digital Caviar Black 1TB (6 Gb/s)
I don't really understand the HDD much, but this seems like a good solid drive. One thing I'm still wondering is whether it is worth it to go SSD. Suggestions, once again, welcome!
Video Card: Most likely I will go a 5850. I don't know which 5850 brand though, there are tons of em. Whichever I can find cheapest probably.
OS: Home Premium I'm pretty sure about this, correct me if I'm wrong.
Heat Sink EDIT: Going with XIGMATEK Intel Core i7 compatible Dark Knight-S1283V REV.W with ACK-I5361 120mm Long Life Bearing CPU Cooler Good reviews and dummyyy suggested it. Seems cheap also.
So far this is coming out to 1.25k, which may be pushing it a little. If you have any suggestions to knock it down feel free to suggest! Also, still curious if SSD physically replaces the HDD.
