Building new gaming computer...entering AMD territory...need opinions on my setup...
Okay...my computer took a major dump. So I plan to upgrade...here is what I've got so far:
Case - Lian-Li PC-V1200B or PC-V1000....(by the way...wtf is the difference!!?)
Motherboard - Abit AN8 Ultra (opinions!?)
CPU - AMD x2 (BUT WHAT KIND!!?? and YES...I do plan on OCing!)
Video - ATI X800XL DVD 256 PCI-E or.... ATI X850 XT PE PCI-E...this will depend on the price I can get it for.
I was able to salvage my WD 74 gig Raptor HD and my WD 200 gig Caviar IDE HD and also my 2 sticks of OCZ PC4000 Gold Edition RAM sticks and my Plextor SATA 716SA Sata Drive and hopefully my SB Audigy! 2 ZS (either way I'll be getting the X-FI Elite Pro..so the sound wouldn't matter too much)
You see the idea here is to get a pretty fast system going. When Crossfire motherboards start coming out... I will then upgrade to that and move my AMD x2 CPU over along w/ either my x800xl or x850 xt pe. And of course all the other goods like my OCZ and HD's...etc....
I also plan to redue my whole Pelt/Water cooled system, but for the time being will just pick up a Thermalright XP-90C heat stink and throw a 92mm Panaflo on it (probably.)
I'm looking to get the goods to start a major gaming machine when crossfire technolgoy finally comes out. This system I'm building now will all be PRE-CROSSFRIE...I guess...The only major trouble I'm having thus far would be the choice of CPU. I've been with Intel for the last couple of years and here I am stepping into AMD territory...and X2 at that. Pretty excited but just not sure which one to pick up and which on will get me to the highest possible OC. My last system (the one that just failed) was a P4 3.2 HT Northwood OC'd to 3.8 stable at stock voltage! And no! the OCing had nothing to do with my last system failure. It had something to do with a crappy-dirty AUX PSU relay switch that failed...which caused major overheating to the point that my tygon tubing had melted getting coolent all over the case and compnents. I was lucky to salvage my x800 XT PE AGP card. Its a long story....
so thus far...one do you think of my new computer specs!? Would it have some great potential in carrying over in to the Crossfire world?
thanks!
thanks!
