- Jan 7, 2014
- Munich, Germany
At Sandrat's request I've been working on condensing his transformer supplied low voltage AC breadboard into a PCB. The PCB will do 3-4 amps happily enough, though the 7812 regulator will need a hell of a heatsink given 14VAC input and a 4 amp fan (19.8vDC peak, 7.8v drop * 4 amps = ~31 watts of heat). Not sure what I'm going to do about that on a PCB level. Switching to a ~10VAC transformer would drop it to 8-10w of heat. A switching regulator would be lovely, but they're expensive once you go beyond an amp and a half.
here is a link to the 78Sxx regulator datasheet.
http://www.produktinfo.conrad.com/d...-01-en-SPANNUNGSREGLER_78S12CV_TO220__STM.pdf
The maximum output current is 2 amps.
