Oh I thought you meant the 5v circuit. I don't see any reason to stabilize the 12v rail because the fans should do that already themselves!
Hi,
Ive been lurking on this forums for quite a while and was interested to build a PWM controller but will be used for pump (MCP35X2 to be specific). Also I'd like to connect it on the 3 pin fan controllers.
Will this circuit work to control the pump with no issues?
So folks, here's an update for you.
Yesterday I received 6x PFC1212DE (8-pole, 3.24A version, measured 1.99A @ 100% with DMM)
Tach doesn't work and the fans have a very strange revving behaviour and an equally strange PWM behaviour. From 0-20% fans don't spin at all, and lowest speed seems to be around 1500-2000rpm at 20%, and speed seems to go up in steps. VERY NICE sound profile though. No idea where the 3.24A rating comes from!
For all the knowledgeable designers here on the board.
I have assembled Bings 0-100% PWM controller c/w the Kickstart component. The fan I am using does not drop to "0" RPM, but does slow to perhaps 100 or so RPM. Is this perhaps the result of the fan I have?
Now that I have rebuilt the Kickstart circuitry (with correct resistors this time) I notice that the system operates opposite to that which Bing intended. When I turn on the power, the fan runs at very low RPM (the length of time is determined by the capacitor rating as shown on Bings circuit) then increases speed to that called for by the potentiometer.
This seems to hint that I have made and error - any suggestions anyone?
Also, I would like to understand how the Kickstart circuit works, and also understand why one of the NPN transistors has 2 leads running to ground - anyone want to take this on.
As a newcomer to electronics, I am simply trying to learn.
Lenny, here is a couple of pictures of my project. I am happy to say the circuit is working well. The circuit at the left of the picture is a 12 & 5 VDC power supply I could elsewhere at the "Internet Engineering Design Company".
The only variance I can detect between the description of 0 - 100% circuit and mine is that with my build the fan does not drop to 0%. This is no problem for me.
Hmmm seems I am unable to attach my pictures. . . . suggestions?
