PS Am I right in thinking that to change the frequency of the 0-100% 556/311 controller, only C1 needs to be changed? I was considering using a selection of caps on a rotary switch for selectable frequency without having to manually pull out and insert caps of different values...
oops,
was too busy watching the vid and missed the rest of the post
yes, the frequency can be easily changed by subbing C1.
changing the whole RC network will be better, but swapping C1 quite ok.
heck.... now I'm thinking about changing the whole R/C network on my controller, LOL.
and again, using the rotary switch was quite an idea.
just please be advised, that by using a regular "break before make" type swicth will make the controller lose a working frequency for a while.
my best bet, the fan will run at their full speed between the switching process.
you can use the "make before break" type switch to solve the issue,
but here where I live, these kind of switches were quite hard to find and pricey.
8-10amps
I think something's worth to wait
I'm currently running my controller with C1=820pF, and quite happy with the result.
now since we mention about changing the whole R/C network,
I probably will try that too, then start making a new controller with the best R/C result.
subbing R3 and R4 with a pair of 10k trimmer was on the list too.
I'm thinking about a 5 channels controller; 2 pwm channels to drive 9SG in two groups, and 3 regular channels to drive a bunch of PAPST, WFB and EFB.
we'll se if I can put them together on a single board or split them onto 2 separate PCB.
knowing that huge cooper land works as heatsink really inspired me
