Okay I've put together a list of what parts are needed to build Bing's 0-98% controller. There were a lot of specifications about the parts that I wasn't sure about. For instance, how many watts the resistors need to handle, what the voltage rating the on caps should be (except the one where it is mentioned) etc.
Can someone please double check these parts to see if I'm making any mistakes. I don't want to have to put another order through digikey.
2X Diodes
100K Potentiometer
1K resistor
10K resistor
470 pf Capacitor
0.01 uf Capacitor
10 uf capacitor
0.1 uf Capacitor
TLC556
Circuit Board
2X Fan headers (This probably won't fit in the slots of the above circuit board)
4 pin molex connector
Actually, contemplating the datasheets and such, an atmega mcu given a 10mhz clock can output 20khz PWM directly! I'm going to have to get myself a 10mhz resonator and try this out!
8mhz is a standard option, that gives 15.6khz PWM output, that might actually work just fine, we'll have to wait for Bing on that one.
EDIT:
Tested a Kingwin fan (yeah right, don't know the actual manufacturer) and it accepted a 33khz PWM signal direct from my atmega328p microcontroller. I'm going to test the Intel and Nidec fans at some point.
If they all accept it, this may herald a new dawn for fan controllers
Bob, about power efficiency vs pwm frequency, since you're using a mcu based to control that digital pot, it will be easy to set "an exact" duty cyle point compared to mechanical pot which will not be precise as yours.
Prepare the mcu to set at the digipot at few test points, say at 25%, 50% and 75%, and do the test run on the fan with different pwm frequencies while monitoring the fan's speed rpm, the higher rpm has higher efficiency, thats all.
Of course while doing that, don't forget to observe at which freq is the most favorable to your ears while finding the efficiency sweet spot, ok, tad nit picking I'd say, but just want to share my experience in cherry picking the pwm freq.
@InVain
Thanks for the help. Your circuit looks super clean. I was inspired by the design and looked for the smallest parts I could find. I switched the resistors to 1/4 watt ones and got the smallest 100 K pot. I guess I wasn't really looking at the sizes before and they all look the same size in the digikey images
Anyway, what are the copper bridges/links that you have in your PCB? Is that just solid wire? What thickness? I found something on digikey called jumper wires, and the breadboard I'm going to order comes with some but considering they're just wires, they seem awfully expensive.
Hi guys im John
im a graduating student here in the Philippines
i have a special project in school that i need to make a "fan speed controller" to be able to past my subject eventually i don't have any idea how to make that happened so.. luckily i find this site that hopefully can help me
after reading this thread i find it so hard to understand because this is a trial and error for making a "Fan speed controler" that's why im very confuse right now what specific material should i buy and what diagram should i use
can somebody help me .. this is my last hope to past my subject
i only need to build 0% - 100% speed 4 or 3pins
thanks in advance kindly PM me for some guides and tips
thank you thank you
Okay so I am trying to build this thing in a circuit simulator just to see how I can move things around on the PCB without affecting functionality but it looks to me like C4 and C3 are in a loop with no resistance? Since they are going straight from the power source to the ground are they actually doing anything?
I would have posted the circuit simulation that I built, but when I went to get the URL for the applet, it opened another java applet that deleted the whole circuit I had built so I can't really show what I set up. This is the java applet I was using though.
http://www.falstad.com/circuit/
Invain makes the cleanest layouts ever. Very impressive! I like the socketed cap too, I'll have to try that.
On another note, if y'all want to see the three output double-556 PWM thing I put together for Sebas for Miah from Bing's schematic, there's a pic mid way down the first post of this thread. Pic#3.
There's another alternative, if you rotate both zener diodes 180* that should have the exact same effect on things.
Might be easier then rewiring the thing to just desolder and resolder those two parts.
