- Thread Starter
- #41
Why on Earth anybody puts barbs on a heater core is beyond me. It's not that I don't have the tools or can't do it, I've plumbed whole kitchens, but it's just not necessary. So far I've used a total of four heater cores and have as yet to add a barb to one. 1/2" tubing goes right over the end of 1/2" copper pipe - in fact I use a short piece of 1/2" copper pipe as a joiner for my tubing runs outside/inside the case. It's no harder to put 1/2" tubing over 1/2" copper pipe than it is to put it on an MCP-655 pump and, trust me, with a single screw clamp the tubing is NOT coming off the pipe. I doubt it would come off without the clamp but I'd rather be safe than sorry.
I should note you do need to cut off part of the pipe that comes with it but a $4 hacksaw can do that in ~5 minutes - if you take your time ...
I thought the '77 heater cores came with weird size pipes, not 1/2"..
Anyways, I've got a pipe cutter (the kind you spin around the pipe)... I ended up buying it when I was trying to run water to my fridge... My hacksaw kept messing the pipe up because I didn't take my time..
