I did a clean format of my HD and reinstalled Xp for starters then windows updated, chipset drivers, then ATI drivers, then the Audigy drivers.
During movies and games I hear this irritating noise so start to uninstall the Audigy drivers using add/remove thinking it just needs a reinstall.
When I try to remove the drivers it reboots ( crashes) prematurely before unistallation can be completed.
Changing speaker settings from 2.1 to 4.1 also forces XP to reboot ( crash)
Tried to use the setup.exe from the install disk then choose uninstall but that didn't work either .
Any ideas will be welcome.
