- May 26, 2003
I have a XP 1700+ Palomino using a Asus A7V266-E Motherboard.
I've connected the L1 bridge using the mod on Tom's Hardware site ( plug the perforations using Superglue, connect the L1 bridge using a conductive lacquer ... ).
My Multiplier has always been set at "11x". When I try to change it to another value now thru the BIOS, my computer will not boot up anymore. I'm brought back to the BIOS automatically after doing a cold boot so I can change my setup. I changed it back to "11x" and all is good.
Anyone have a idea what could be the cause ?
My current setup is :
WinXP
256mb DDR PC2100
Athlon XP 1700+ Palomino
FSB set to 145
Vcore : 1.85v
MemV : 2.8v
Cpu temp : 55c
Thanks for the help
WinXP
256mb DDR PC2100
FSB set to 145
Vcore : 1.85v
MemV : 2.8v
Cpu temp : 55c
Thanks for the help
