- May 13, 2010
Hey guys, sorry I wasn't sure if this was the right place to post this or not but I figured it would be the best place since it has to deal with PSU's
The issue I am having is that I can not get any of the pins in my corsair 1000 to come out.
I tried both the pci and the atx.
I am using the sunbeam kit to remove them but it seems like the tool cant slide down far enough to push the pins in.
Now I was able to remove all of the pins in a an ATX extension that I have with this same tool with no problems.
So if any of you have dealt with the corsair and have had this problem, or if you have any advice please sound off I greatly appreciate it.
Edit****
I got it taken care of.
Found out in order to get something to fit in correctly I had to push the wire up as I inserted the tool
Edit****
