Owenator said:L337 M33P,
To use a term from your side of the pond, I believe. You are 'spot on!'
You have articulated what I did not. My concern is for our application (CPU cooling) not an academics lab test, so what better way to test it than to make some up and let someone test it with a die simulator, JoeC perhaps? Would he have access to the materials and apparatus? I can see a lot of issues with shippping the mixture premade as it might evaporate away if it were shipped. Perhaps if the mixtures were made and put in sealed containers they could be shipped and tested in a "grease off" a-la Dan's data?
O
BillA said:the BillA formulation, lol
please send some to pHaestus too
(pHaestus, get Nevin your addy)
many thanks Nevin
be cool
Owenator said:
Do you think they can make it in Black?
Sorry to be a wisenheimer but I just couldn't resist. I haven't been sleeping much lately also ....
O
By Nevin: The advantage to water as a TIM is that it evaporates and carries away heat.The disadvantage to water is that it evaporates and eventually you have a dry joint and soon a dead CPU.
Nevin: You have a good memory. For heatsink testing on hardware sites, I have considered releasing a short-term use only thermal compound that does not require any break-in. Since it achieves optimum performance within a few minutes of application, it allows more efficient and consistent heatsink testing. The downside is that it only lasts a week or two at most.
Freeloader said:
When I tested the water as a T.I.M.,I encircled the Die with with a bead of thick non-conductive grease which created a seal to prevent evaporation. It is my theory that the water worked better because it was better able at filling the micro crevises in the heatsink and die and ,or it allowed a smaller gap with the two surfaces providing more direct physical contact. If the main strength of the carbon black is the small particle size, then this may explain why I saw an improvement with the water.
