- Nov 25, 2001
- Niagara Falls, Ontario, Canada
Okay, few observations about fillers in a heatsink compound, say if the best metallic conductor there when rendered into particle form made pyramid shaped particles, at one side of the interface or other there would basically only be point contact. Therefore a substance that is less conductive but has a more convenient particle shape to offer more surface area of each particle to the mating surfaces and/or a smaller particle size and thinner layering is going to do better.
Now, copper as you know is a good conductor, but say we made it into copper wool and stuffed it round something hot, it would probably then be a fair enough insulator. It's not the material it's the air it traps.
Saying you can't make an insulator out of a fairly good conductor, or a thermal interface material out of a fairly poor conductor is on the same level as saying you can't make a boat out of steel because a block of steel sinks.
Zinc oxide paste which is still a production TIM, and is still just a small percentage away performance wise from exotic current compounds uses a very poor conductor, Zinc Oxide. Zinc oxide by itself is really truly a bad conductor of heat, it's probably worse than the average microwave safe coffee mug. So if it's performing within a few percent of silver compounds, there's obviously something not quite as straightforward about TIM design as you would like to beleive.
Anyway, on to patenting. Well a quick search on google revealed evidence of prior art using carbon black as a thermal filler, so probably only the specific formulation can be patented, I don't see much hope of there being a very broad patent issued, which leaves us guys considerable leeway.
Interesting observations about evaporation, that hadn't occured to me. I was presuming that the application was just as good when dried out as long as the joint was not disturbed.
regards,
Road Warrior
regards,
Road Warrior
