So I built my first computer with you guys almost a year ago. It was a budget rig and I pieced it together with what I could afford. Reference the thread here if need-be: http://www.overclockers.com/forums/showthread.php?t=656697
It held me over for a while, but recently I found myself power hungry. I went ahead and replaced the 5770 with a 6950. With a little research I found out my motherboard is going to have a BIOS update that will support AMD's new line of Bulldozer processors. I will definitely be purchasing either the 4 or 6 core variant of that processor, my question is in regards to the actual swap.
My current Phenom II 555 is overclocked and has one additional core unlocked, will those settings be reset after the card is removed from the motherboard or are they saved? Will they affect the normal clocking of a new bulldozer card and is there anything I need to do to reset them aside from pulling the mobo battery and re-seating it?
Thanks
Thanks
