Here's my test setup:
SEE THE MACHINE RUNNING (if you want to see how chilly it's running)*:
http://downloads.pcrpg.org/video/computer/Tectanic Running.mkv
(or for those of you who would rather just have an avi)
http://downloads.pcrpg.org/video/computer/Tectanic Running.avi
That's the result of my latest experiment dealing with computers. Last weekend I machined a water block from scratch with a drill press, a Dremel, ultra-strength epoxy, and about fifteen hours of time. (video coming later)
Today my 320W TEC arrived, so I prepped the Athlon XP (yeah--remember those?
) I was going to do the experiment on. After an hour or so, I was ready to roll. The video shows the result of my initial test run.
Running idle the setup pulls about 450 watts, and that's with the TEC only getting about 11V (around 160-180W). I'd give it full voltage, but I've got no supplies currently capable of doing so. I'm using a faulty Antec True550 for it currently. It's got a bad 5V rail (4.1V), but the 12V is fine. It's just sucking a lot of juice.
Total cost for experiment: $31
Total time: About 15-16 hours.
The more time you spend on something, the less it'll cost ya.![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm not sure how high it will clock yet. I don't really get much time before the power supply's wires are ready to melt, but I do intend to find out one way or another. On air, this chip was known to be stable around 2200-2300MHz.
* If you're having trouble playing that video but would like to see the machine running, you've got two options more or less.
1) Install a player with built-in support for Matroska containers (.mkv files) with xvid video and vorbis audio such as VLC.
And/Or
2) Install a DirectShow filter pack that adds support for Matroska containers with xvid video and vorbis audio so you can play it with DirectShow based players (such as Windows Media Player). Such a filter pack would be CCCP.
![tec5.jpg tec5.jpg](https://www.overclockers.com/forums/data/attachments/241/241403-815ccb9224d732f634af600fd6fd041b.jpg)
![tec2.jpg tec2.jpg](https://www.overclockers.com/forums/data/attachments/241/241404-75f736ac855f97b4ec85dce3c43e2aab.jpg)
![tec3.jpg tec3.jpg](https://www.overclockers.com/forums/data/attachments/241/241405-efbb19a8baa0d31fdcd8a873196e5e28.jpg)
![tec4.jpg tec4.jpg](https://www.overclockers.com/forums/data/attachments/241/241406-b2ac7026419642881d8b16e5b1d09be9.jpg)
![tec1.jpg tec1.jpg](https://www.overclockers.com/forums/data/attachments/241/241407-eadb589dfe3fadfe46cb5b0551a7ed94.jpg)
And/Or
