WiNnErPL said:For 49 shipped that's a real good deal, not alumniunum however
bterry13 said:... Do you think this case is better than the case at the following link...
Silversinksam said:Aluminum cases are over-rated if the pc is static and you have good airflow. If your a LAN player aluminum is the way to go due to the weight.
whooping_a_panda said:i jumped on it, the chieftec/antec cases are pretty nice, my only gripe is theres no place for 120mm fans... but that can be fixed..
*revves dremmel*
ill finally be rid of this tiny tiny case i can barely get 2 hdds on the same cable and on the motherboard cause the cables to big...
