- Feb 25, 2004
- N of splat W of Torin
Good luck to the Canucks! Thanks for the linky!
Just be sure to put up a big "WE NEED YOUR HELP!!"I'm going to get something up on the front page on Monday or Tuesday, about the Chimp Challenge.
I'll cover the rules, dates, etc. Does anyone have anything else they'd like mentioned as part of the Chimp Challenge announcement? Can anyone knock up a logo and/or provide some images of a folding farm to provide a bit of colour for the article?
Launch directory: /home/hbarta/folding
Executable: ./fah6
Arguments: -configonly -smp
[13:19:10] Configuring Folding@Home...
User name [Anonymous]? HankB
Team Number [0]? 32
Passkey []? <entered my personal key>
Ask before fetching/sending work (no/yes) [no]?
Use proxy (yes/no) [no]?
Acceptable size of work assignment and work result packets (bigger units
may have large memory demands) -- 'small' is <5MB, 'normal' is <10MB, and
'big' is >10MB (small/normal/big) [normal]? [B]normal[/B]
Change advanced options (yes/no) [no]? [B]no[/B]
[13:22:16] - Ask before connecting: No
[13:22:16] - User name: HankB (Team 32)
[13:22:16] - User ID not found locally
[13:22:16] + Requesting User ID from server
[13:22:17] - Machine ID: 1
[13:22:17]
[13:22:17] -configonly flag given, so exiting.
Terminated
At the moment I'm just tailing the log. Haven't even finished my first WU!Are you running HFM to keep track of how much your doing?
THe team name is the most important to get right. It is T32monkeys NOT T32Monkeys. As long as EOC is used for stats ...
So to be very clear, if I get 10 WUs done using "T32moneys" and my passkey all will be good, correct? Or alternatively, I can use passkey David set up for T32 monkeys?THe team name is the most important to get right. It is T32monkeys NOT T32Monkeys. As long as EOC is used for stats and they are aggregated as they were last month, there should be no reason to use the T32monkeys passkey, except bonus qualification. In my case I qualified my passkey with the T32monkeys username years ago and plan on leaving my passkey as is. If you haven't qualified the T32monkeys user name to your passkey, you should use the T32monkeys passkey. If it isn't already, I think that passkey should be public.
Is there anything special I have to do to donate to both T32 and T32Monkeys???
Where do you change the name? I don't recall seeing that anywhere in my setup. Is that part of the FAH setup or part of some third party monitoring app? Is that required to participate in the contest.Just change the name to T32monkeys NOT T32Monkeys leave team number the same and get the passkey of David. Then you're ready to fling poo
Can I please have the passkey? Got my setup ready, just in the nick of time
David, a few things:
1. The top post says that using the T32 passkey is optional. You have to read this whole thread to find out it's required for T32 to get credit for SMP WUs. Can you please clarify this in the first post.
2. There are instructions in the first post. Could you please clearly tell people what they need to do to fold for T32 (ex: 'Change your user name to "T32Monkeys" and change your passcode if you're folding SMP WUs. Please ask me if you need the passcode.') I'm concerned that the optional passcode is going to cause some confusion.
3. Let me know if you need help getting 10 SMP WUs completed.
Edit: David, Can you go back to your first post and enumerate the requirements to participate in the contest? I think you've done a pretty good job of describing the rules that determine which team wins (or not) but the requirements that I need to complete to contribute seem to be scattered through the thread and are not at all clear to me. Please do not assume that willing participants have any familiarity with FAH.
I don't see why I care, so I'll likely use the T32 passkey.
Team Number [0]? 32
