First, I realize with this build it will be closer to $1100-1200, so be it. I can throw in some extra cash since most will be given as presents. But, I need to get my list out by about Thanksgiving. If there will be massive sales, I can wait on those parts and purchase them myself and leave the rest as gifts.
I already have a CM Stacker case with plenty of fans, so all I need is the hardware listed. I play mostly WoW, Skyrim, Dark Souls, and games of that nature. Pretty much always RPG games, every once in a while FIFA. Playing on a 60 inch plasma 1080P. Noise of fans etc. is not really a concern. I don't plan to OC right off the bat, but probably will in time. Regardless, it will probably be mild OCs. Any other questions / reqs I need to answer let me know.
PSU - Corsair CX Series CX750M 750 Watt ATX Modular Power Supply - $69
http://www.microcenter.com/product/406089/CX_Series_CX750M_750_Watt_ATX_Modular_Power_Supply
The 750 is only $7 more than the 600 so I figured what the heck. I would prefer a modular PSU, but if there is a much better one I am willing to go that route and simply hide the cables. If the rebate ends, I will go back to the 600 series, as I think that is more than enough for what I am running.
RAM - G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) - $82
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231666
Was recommended 16 GB in another thread at a low price, but I figure when the time comes I can simply buy 16 GB or buy another set of these.
M/B - Asus z87 A - $140
http://www.amazon.com/Asus-Z87-A-DDR3-1600-Motherboard/dp/B00CRJSV9O
I was recommended this board, but there is a newer version, the Z-97, so I will probably buy that one unless the 87 is better for my setup.
CPU - i5-4670K Haswell - $234
http://www.amazon.com/Intel-i5-4670K-Quad-Core-Desktop-Processor/dp/B00CO8TBOW
Told this was more than enough for my gaming needs.
GPU -
Here is my issue. When I asked before, I was told an R9-280X, but I see there are new versions out since then. I would like recommendations here both on what model and maker to get.
HD - Samsung Electronics 840 EVO-Series 250GB - $128
http://www.amazon.com/Samsung-Electronics-EVO-Series-2-5-Inch-MZ-7TE250BW/dp/B00E3W1726
I do not need multiple drives, I don't keep a ton on my computer. Even a solid 128 GB would be fine if it was better than this, but it seems this is a pretty good drive and the 250 GB is the version I need to get over the 128 GB because the bigger one has 8 channels or something. I won't pretend to know.
Heatsink - NHD15 - $95
http://www.amazon.com/Noctua-NH-D15...&ie=UTF8&qid=1415289510&sr=1-1&keywords=NHD15
I suppose I could go with something cheaper, like the 212 since I won't be doing massive OCing. Could put that money into my pocket, or a different PSU etc. Seems like a good choice and future proof if I OC though.
Windows - Windows 8.1 System Builder OEM DVD 64-Bit - $92
http://www.amazon.com/Windows-8-1-System-Builder-64-Bit/dp/B00F3ZN2W0
Just because.
Random - Arctic Silver $8
I don't have any left from my last build
Any items I can get at a Microcenter, assuming the savings is worth it, will be done by me in person. So I can leave the items not at Microcenter or only marginally cheaper to be purchased for Christmas.
Thank you for your time ~
GPU -
Just because.
