Just completed the build listed in my signature, been at least 6 years since last complete build and OC. So, I have been having to research and relearn. I am needing some guidance on how to proceed with my overclock. Below I have listed current BIOS setting for my OC. My OC procedure was to slowly increase the Core Ratio (wanted 4.9 or 5GHz), reboot, run Cinebench till PC froze/bluescreen, reboot increase Vcore rinse and repeat till was stable with Cinebench. Did this till I got to Core Ratio I was shooting for then ran Prime95 V29.5 Custom with Min/Max FFT Size 1344, Run FFTs in Place, and time to run each FFT set to 15 minutes. If OC made it 30 minutes of custom test, I would then run Prime95 Small FFT, otherwise would adjust VCORE and try again. I could never make it past 90 minutes with settings below running small fft in Prime95. I was seeing temperatures between 68-80C during small FFT. It felt like I would have to keep increasing my VCORE to make it 2+ hours with Prime95 small FFT which I am concerned would be close to 1.4 VCORE or more.
I have read that Prime95 version I have installed uses AVX2 which really loads and heats up the CPU more than necessary. This PC is primarily for gaming with some web browsing, picture editing, music and movies, so limited to no AVX usage. Should I put an AVX Offset in and rerun Prime95 knowing I am really stressing OC at a lower frequency or run pre-AVX version of Prime95? Is 90 minutes of Prime95 small FFT with AVX2 sufficient and move on to running AIDA64 and Realbench for more real world stress testing? How long should I run each to consider OC stable as time seem to vary from all forums I read?
Also, CPU was re-lidded using Thermal Grizzly Conductonaut. I have been using Coretemp and HWInfo for monitoring.
AI Overclock Tuner - MANUAL
BCLK Freq - 100
AVX Instruction Core Ratio Negative Offset - 0
CPU Core Ratio - SYNC ALL CORES
Core Ratio Limit - 49
IA AC Load Line - .01
IA DC Load Line - .01
CPU Core/Cache Voltage - ADAPTIVE MODE
Additional Turbo Mode CPU Voltage - 1.33
Load Line Calculation - 5
BCLK Freq - 100
