I need a little assistance with my current gaming machine. The specs are listed below along with the upgrades I ordered.
Mother Board
XFX MB-N780-ISH9 LGA 775 NVIDIA nForce 780i SLI Intel Motherboard 3-Way SLI Support
http://www.newegg.com/Product/Product.aspx?Item=N82E16813141005
CPU
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor BX80562Q6600
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
Memory – (4 GB Total)
Kingston HyperX 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model KHX6400D2LLK2/2G
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134066
Video Cards – (2 Installed SLI) I have a 3rd one also.
XFX PVT98WYDBF GeForce 9800 GTX+ Black Edition 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150327
Power Supply
ABS Tagan BZ Series BZ900 900W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Modular Active PFC Patent Piperock Modular Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817814013
Hard Drives (4 Installed in Raid)
Western Digital Caviar RE WD2500YS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136055
Case
XCLIO A380BK Fully Black SECC 1.0mm thickness ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811103010
Current Upgrades Ordered
SSD
OCZ Vertex 3 VTX3-25SAT3-120G 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227706
Memory – (Ordered 2 sets to make a total 8GB)
Kingston HyperX 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model KHX6400D2LLK2/4G
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104020
I wanted to get this machine a little up to date with out spending a massive furtune.
As I mentioned before, I currently still have a 3rd 9800 GTX+ I never installed in my computer, When I ordered my original PSU, I thought I was unable to hook up 3rd 9800 GTX+ video cards in SLI because of the power cable hook ups I was limited too. So the card sat unused for a few years. This all changed when I saw this video.
The computer in this video has the same PSU, Tagan BZ900 with 3 XFX GeForce 260 GTX in 3 Way SLI.
After doing some research, I have come across 6 pin PCIe Splitters. I am not a “power guru” so I am not sure if I can use these types of splitters but if I can, how would I hook it up properly to avoid power issues?
Mother Board
CPU
Power Supply
Case
SSD
