Ok guys need your opinion and reasons....
If you were building a constant speed control motor at relatively low voltage what type of motor would you want to use shunt, series, or compound motor. And the big thing I am looking for is why.
This means that on start of the motor you should have a constant speed and if resistance or voltage is changed to the armature load, the speed should remain at a constant speed when load is changed.
I have done some research on the motors, but am having trouble which to look in the deapest. Can someone steer me in the right directions.
