- Sep 14, 2002
- Chico State. GOT MOFO?
Copper...Copper!!!!
maskedgeek said:i tried google, i heard you can get diamond plates, or something like that, i would like to get ahold of a 2x2 or 2x3 peice.... dunno how possible that is...
Since87 said:
I don't have any idea. I'd use google to find out.
I think most industrial diamonds are made in tiny sizes because they are used by embedding them in metal to make grinding and cutting tools. I don't think there is actually any practical values to diamonds in watercooling.
I suppose you could conceivably cast a baseplate for a WB with diamond filled copper. I think all the copper/diamond interfaces would limit the usefulness of something like this. Depending on thermal expansion characteristics, the diamonds might be rattling around in little air (or vacuum) pockets. That would be very bad for the thermal conductivity of the baseplate. [/QUOTE
If you do this keep your hours on lapping the bottom for us. You using wet dry paper? LOL
Mr.DLucey said:If you do this keep your hours on lapping the bottom for us. You using wet dry paper? LOL
McWarren said:I've been told that although copper is a better heat conductor, aluminium can dissipate it quicker.
