- Dec 19, 2005
- New York
Dear Fellow Brothers of OCForums.com. Just wanted to wish everyone a happy belated new year and holidays. Most of you know I have been gone and out of the loop for almost 2 years now. Well, I did a favor for my Aunt and Uncles PC for the holidays and upgraded there cooling system to the new Corsair H70. They decided agains a custom loop and asked me for something entry level into water, but slightly better than there TRUE setup so I made the H70 recommendation. Initially when I built there PC I used a TRUE120with dual Noctua SF12 in push/pull. So, I will give you a comparison of the results. We are pleasantly surprised at the results here in all honesty. I initially built his rig with your standard 4.0 Ghz D0 overclock in mind, and he has been using it flawlessly for over a year a 4Ghz, albeit very high air temps, but flawlessly indeed.
QUICK NOTES:
20 X 200 . 4.0 GHz @ 1.32vcore both with the TRUE and the H70, so everything was identical both before and after the testing, so like a car all we did was swap 1 part for another part and turned the key. I chose to configure the Corsair H70 Radiator with 2 fans in push/pull intaking the cold air from outside the back of the case, pushing it through the radiator and dumping into the enclosed case, than I changed the configuration of my fans around and used the two old Noctua SF12 fans (which are excellent fans taken off of his TRUE setup) and used them to empty the hot air from the case and spit it out of the top of the case. Thankfully I have dual top fan slots on the case which helps out with this new setup trememndously otherwise we wouldve been simply dumping hot air right into the case over the memory and mobo and heating up average temps in general over time. Strangely this is corsairs recommendation, pulling cold air into the case through the rad. In my mind, this only works if you have an ample exhaust configuration like so.--System Config--
***hyperthreading is DISABLED on his PC, he is a gamer.***
CPU: Core i7-920 D0
Ram: Corsair Dominator GT-1866 C7
Mobo: Asus P6T-Deluxe V1
PSU: Corsair HX620
GPU: Sapphire 5870
-I did not use Linx for testing, I used Prime95, so although these arent Maximum Pressure Stressed results, they are blended cpu/mem results and not total maximum temp. On my own PC I would use Linx, but I felt since they have been running flawlessly at 4Ghz on air for over 1 year now, Prime95 is all I would need for a homeowner. This is a homeowners PC, and they only use it for photos/video/music/ and gaming so I just ran Prime95 overnight last night for 12 hours passing, and just ran it for 30 minutes or so now to give you a screenshot of basic loaded temps. ** All temps are averages from the testing.
-I do not have screenshots of the TRUE results but I have averages that my uncle Rick had marked down from my initial build and from his own personal pre-corsair h70 review. In any event, the gains are to his liking. Ambient temperatures were always 70*F in the computer/work room without any variations ever.
TRUE120 Extreme with push/pull Noctuas
Average Idle Temps (1.32v 4Ghz) : 46*C
Average Loaded Temps (1.32v 4Ghz) : 83*C
Prime95 was used, regular blended stress test. Nothing too crazy was used. Just your average Prime95 blend to heat everything up a bit.
Corsair H70 with Dual Corsair Stock Fans @ 2000rpm HIGH setting PUSH/PULL
Average Idle Temps (1.32v 4Ghz) : 38*C
Average Loaded Temps (1.32v 4Ghz) : 69*C over 12 hours
Prime95 was used, regular blended stress test. Nothing too crazy was used. Just your average Prime95 blend to heat everything up a bit. Note that screenshot is not 12 hours, ss is only a quick 30 minute load burst to show you guys the numbers quickly:
Decrease in idle Temps vs. True: 38*C vs. 46*C, 8*C Decrease.
Decrease in Loaded Temps Vs. True: 69*C over 12 hours vs. 83*C over 12 hours, 14 degree decrease.
And finally, just for craps I did the stock 2.66 Ghz Core i7-920 D0 temps, sorry guys no screenshot on this one.:
Average Idle Temps (1.10v 2.66GHz) : 27*C
Average Loaded Temps (1.10v 2.66 GHz) : 44*C loaded for 30 minutes
In conclusion, my family is very happy with the cost to performance of this little water cooling kit. It took me all of 20 minutes to install it, testing took 2 days but all in all it was definitely worth the money for them. I paid 109.99 at Microcenter *edit. The best part about the install for TRUE owners is the TRUE120 backplate actually works perfectly for the H70 mount so I was real happy about not taking the whole rig apart to simply install the radiator and water block. Thats why the install only took me 20 minutes or so. Another thing I noticed is the size of the single radiator is tremendous, I dont think I remember seeing anything this big, it is much bigger than the H50 thats for sure. In any event, my aunt and uncle are now cruising at the same speed but approximately 15 degrees C cooler when loaded and playing games which is what they requested. 83*C was not an acceptable temperature for them, so I took a chance on the H70 and it seems to have worked out so far. Lets keep our fingers crossed. Well, thanks for reading guys/gals. As far as further testing, thats it fellas, on his rig I am done for now. Mission accomplished. To all my old buddies, hope all is well!
Cheers,
Dominick
