- Jan 12, 2002
- down at fraggle rock
ok, i'm running an xp 1700+, radeon 8500, sb xgamer, 256mb DDR, and a dvd/cdrw drive on a 300 w PSU.
Currently i have 1 80 mm fan plugged into the mobo and the CPU fan is plugged into the PSU via a molex adapter. I am planning to add 1 or 2 80mm side fans, a 60mm exhaust fan on the back, and a ram cooling fan if my PSU can handle it. So basically what I want to know is: what is a safe number of fans that can be run off a 300w PSU? I have molex adapters for these so they'll be run off the PSU and not the motherboard.
Also, what's a good setup for the side fans? should I have one blowing on the radeon and another blowing on the CPU fan?
anyways, the dragon orb's about to come off so i can replace it with a millenial glaciator....hopefully this airflow will drop my temps from 42c that i'm seeing right now to something nice and frosty.
