- Jul 8, 2004
- NEW YORK
I need help because i know not what i do. Stock speed is 2.0 gig at 39*c idle
-External clock at 133
-CPU multiplier at 15X fixed
-CPU/DRAM ratio set to auto
-AGP bus 66 mhz
voltages are
-CPU 1.6
-DDR 2.6
-AGP 1.5
Right now i over clocked to 2.22 running stable 42*c idle
-External clock at 148
-CPU/DRAM auto
-AGP bus 70 mhz
Voltages are
-CPU 1.7
-DDR 2.6
-AGP 1.7
Failed options
-External clock at 150 <----- windows crashes apps fail at voltage CPU 1.6 at CPU voltage 1.7 windows runs stable
but my games crash every time
-CPU/DRAM auto
-AGP bus 66 mhz
Voltages are
-CPU 1.7
-DDR 2.6
-AGP 1.7
My Heatskink is thermaktake extream 80m fan my temps are cool
Ram is 512 mb DDR PC3200 (DDR400 200mhz)
PSU is 350W
MOBO NF7 a-bit
CPU athlon (tm)xp 2400+
(a) so given the options here can i got past 2.2gigs stable can i max out all my voltages then up the External clock to 150
again or with puting my voltages to high harm my sys.
(b) So far i know what the external clock is but is it also known as the Front side bus? or is the FSB determined with the
CPU/Dram ratio because i noticed at 133 external clock it says 266 on the boot screen and at 148 external it says 300
on the boot screen
(c) the DDR pc3200 says DDR400 dose that mean 400 MAX FSB?
also it says 200 MHZ where dose that come into play
(d) What is the external clock the CPU,DDR or MOBO ?
(e) My vid card is nvidia FX 5700le 256ddr what dose the AGP bus need to be set to for max performance
-AGP bus 66 mhz
voltages are
-CPU 1.6
-DDR 2.6
-AGP 1.5
-CPU/DRAM auto
-AGP bus 70 mhz
Voltages are
-CPU 1.7
-DDR 2.6
-AGP 1.7
Failed options
-CPU/DRAM auto
-AGP bus 66 mhz
Voltages are
-CPU 1.7
-DDR 2.6
-AGP 1.7
PSU is 350W
MOBO NF7 a-bit
on the boot screen
