- Sep 17, 2001
- Federal Way, WA
Ok..here is what I plan to do..
slk-800, 80-120mm adapter, and the 120mm 132cfm fan.
If I made an adapter for the fan, and the case to hold some plumbing so its taking air outside of the case(from the side panel), would that be worth the work? Any ideas how much that would help? Maybe also putting the same 120mm fan on the side panel in the plumbing.
I am going to try to equal CFM in and out. I am not sure how much the power supply does...I am going to have 2 exhaust fans. 1 large on the top of the case, and one small in the rear. 2 Intake fans, 1 in the front of the case, and the one on the side. I am also going for quiet. So I will either get big fans to get the cfm, or just get smaller fans and not as much air flow.
