- Apr 28, 2004
Hey guys, I have a 2.8 prescott and whever I use the cpu to move windows around or open and close programs, I hear a faint high pitch noise coming from my computer. Do you guys know what this could be and how I could stop it?
IMOG said:Do you have onboard sound? And is your internal system speaker connected?
It might be noise you are hearing from interference of some sort. Dunno on that, depends what it sounds like.
Does it happen when you run a program that loads the processor without you doing anything? Do your fans change speed or sound? It might be your PSU making noise under different loads - that would sound pretty close to your processor too.
IMOG said:The voltage to his fans shouldn't change under load though... But there is an easy test for this - when you hear the sound, poke the hub of the fan with your finger and slow the fan down noticeably. Does the sound change and seem like it is coming from the fan?
GST-97 said:Most 'noise' that you hear has been found to be caused by the inductors (coils) right around the CPU resonating when the power needs change.
Certain motherboards seem to make more noise than others also.
-Chris
