- Aug 2, 2012
So, I'm currently running 3 HDDs
128GB Sandisk Ultra Plus Solid State Drive
160GB Western Digital Velociraptor 10K Drive
640GB Western Digital Caviar Black
Here is what I am thinking of doing as far as partitioning:
640GB WD Black - Windows 7 Install
100 MB System Reserved
200GB - NTFS - Aligned to Cylinder - OS and Some Games
~400GB - FAT32 - Aligned to MB - Media files, etc to share to Linux
128GB SSD - Linux Mint Install - MBR with Grub
500MB - ext2 - /boot
3000MB - linux-swap - swap
11.5GB - ext4 - /
~110GB - ext4 - /home
160GB WD Raptor - Speedy Data (Specific Games, Applications, etc)
160GB - FAT32 - Aligned to Cylinder
So that's the plan, at least. I have gotten Mint working flawlessly with this SSD partition set up. However, for MBR reasons I now have to go back and install Windows, then install Mint again (though this current Mint install is only about 2 days old)
I was intending to use GParted to manage the partitions from the Mint Live CD. When I set up the partition tables, should they all be MSDOS partition tables? Any benefit to alternatives?
Should I be formatting the 200GB partition to NTFS with GParted, or should I make a 200GB Unallocated Partition and then use the Windows installer?
And one last question, is FAT32 the best file system for accessing data (both files and potentially executables) from both OS environments? I realize I won't be able to run EXE files in Linux or whatever. But will FAT32 partitions properly map to both environments, and accept a Steam Library along with Videos, Music, Pictures, etc? What would be the best filesystem for the 400GB Crossover Partition, and for the 160GB Raptor?
Thanks for any and all advice.
11.5GB - ext4 - /
