- Jul 25, 2004
- Sylva, NC
10,000 up to 14,000(shamino and sampsa )
batboy said:I don't think that even the brand new Cat 5.11 drivers technically support the new X1800 series yet. I would bet money on lots more performance with these new cards as driver support catches up.
The world record for 6800Ultras is 14,623 by Shamino. The X850 record is 15,498 by Macci way pre-release. Both scores were done with extremely exotic cooling, but the X8xx's have always had an edge over the 6800's in 3DMark, so its no surprise that two of them keep the same advantage.Nexus Realized said:Lookin' good Mike.
BTW I never really payed any attention to SLI setup's but what were say...two 6800GT's getting in 05'?
mikeguava said:so far I can see 13k to maybe 14k pretty easily with some better clocks on the cards and a tweaked system.
I am not sure how the P5WD2 handles the PCI-E lanes - But I am prety sure I was runing 16x/4x .
This could - again could - have also potentially slowed my system down.
Another thing to consider I am certain that the CF boards will be also be a bit faster than the 955X chipset- we should find out about the soon enough...
That I was able to run CF I don't think was supposed to be possible - the drivers that cames with the CF card would not allow it. Only using the latest ATI enabled CF.
I am certain next driver in itself will give a huge boost, and if Asus comes out with a bios that allows the distribute the PCI-E lanes t 8x/8x lanes it should give another bump.
Like in 780GTX sli, it is very key to have a FAST cpu - otherwise you scores will be way down.
Jum from 9k to 12k was all in the CPU clocks - and my system wasn't dialed in at all - I was actually doing CPU and running CF becnhes along - mainly focusing on CPU clocks without running a tight memory / tweak system setup - which would have been good for another 500points easily.
Memory bandwidth also helps scores - better to run huge FSB and looser timings than super tight - well that's a given...
The PQ is very good - eyecandy like we're used from ATI - only when the XP intitally starts up do you see some some flickering - i assume to sync the cards - that will also happen with resolution changes.
I think that X850XT CF is a very viable product - as long as you have a very fast CPU and already own a X850XT along with ecoupon from ATI which gives you $100 off ( anyone who purchased a crossifre ready card retail in the past few months can get this).
at a price of $249 ( $299 currently but not much longer..) That for the master card is a great deal.
Otherwise i'd look at some other cards.....
IWasHungry said:Getting a Mastercard in the future is definetly an option for X850 owners like me.
Tomatosaurus[RE said:I want a Mastercard too, with phat credit so I can buy many FX57's.
speed bump said:^^^except 03 there you can't take anything away from Nvidia considering until K|ngp|n came along with a ton of dothan power and took down shaminos single card record 03 record which he held with a 6800U, P4 EE, and Abit AA8xe.
