I was waiting for a Crucial Ballistix Elite DDR4 for couple of months and I think it was worth it as this memory is slightly different than what you could see on our market.
Crucial is rarely releasing new products but many of them are exceptional.
There is only one XMP profile - 2666 CL16 1.2V. I think it's enough and so far I've seen only 2 profiles in Corsair memory. Most enthusiasts/overclockers will use manual settings anyway.
Below you can see how SPD/XMP looks like in AIDA64, ASUS MemTweakIt and CPU-Z.
What is interesting and maybe you noticed that, SPD is starting at DDR4-2400 what means Crucial used higher bin IC instead of popular in most other DDR4 kits - 2133MHz.
Results at XMP settings can be seen below:
and some overclocking results starting from default 1.20V
2400 / 2666 / 2800 1.20V
2400 12-12-12 1.20V
2666 14-14-14 1.20V
2800 15-15-15 1.20V
2400 / 2666 / 2800 1.25V
2400 12-12-12 1.25V - the same settings as 1.20V, look above
2666 14-14-14 1.25V
2800 15-15-15 1.25V
2400 / 2666 / 2800 / 3000 1.30V
2400 12-12-12 1.30V - the same settings as 1.20V/1.25V, look above
2666 14-14-14 1.30V - the same settings as 1.25V, look above
2800 15-15-15 1.30V - the same settings as 1.25V, look above
3000 16-16-16 1.30V
2400 / 2666 / 2800 / 3000 1.35V
2400 12-12-12 1.35V - the same settings as 1.20V/1.25V/1.30V, look above
2666 13-13-13 1.35V
2800 15-15-15 1.35V - the same settings as 1.20V/1.25V/1.30V, look above
3000 15-15-15 1.35V
2400 / 2666 / 2800 / 3000 1.40V
2400 11-11-11 1.40V
2666 13-13-13 1.40V - the same settings as 1.35V, look above
2800 14-14-14 1.40V
3000 15-15-15 1.40V - the same settings as 1.35V, look above
2400 12-12-12 1.20V
2666 14-14-14 1.20V
2800 15-15-15 1.20V
2666 14-14-14 1.25V
2800 15-15-15 1.25V
3000 16-16-16 1.30V
2666 13-13-13 1.35V
3000 15-15-15 1.35V
2400 11-11-11 1.40V
2800 14-14-14 1.40V
