- Jan 28, 2013
- Chicago, IL
I get this error message "crysis 3 has stopped working" error message, usually when in a loading screen or I go into the next area of the game. Either that or I black screen and freeze.
I also same black screen I get when I'm playing SW:TOR, when I first load in to the game or ESPECIALLY if I ALT+Tab and go back into the game. The problem isn't as bad with SW:TOR as it is with Crysis. SW:TOR I can just reboot, and I'm good to go for hours (unless I Alt+Tab lol). Crysis, this happens very frequently when in some sort of loading or transition area.
I'm running Windows 8 64-bit, AMD 8350 4.0Ghz, 16GB Ram, DirectX11, Radeon 7970, Displaying 1920 x 1080 (32 bit) (60Hz)
I've uninstalled all old drivers and reinstalled the newest, that didnt solve the issue. I tried installing the new beta driver, same issue.
I did some research on this issue, found a lot of people having the same issue but no real solid answer. So decided to check on here and see if anyone might be able to find a solution for me.
Ran my DxDiag and here are the notes:
DxDiag Notes
Display Tab 1: The file aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Input Tab: No problems found.
Not sure what the above means, if anything.
I can post my full DxDiag info if requested..
Thanks all!
DxDiag Notes
Thanks all!
