I got a little experiment that everybody at home can play to settle the dispute on acrylic top vs. full copper blocks.
Everybody mark down their temperatures, full load and idle. Then put foam on top of your block, because in essence, that's what acrylic is doing... especially the full copper block people. Test your temps before the foam, and after... if your temps don't rise, an acrylic top probably won't make much of a difference. Of course to be fair you'd have to shrink your channels of your waterblock too... even 1/4th the surface area seems like too much to give up for a pretty hat.
Drastic? probably not, but, acrylic is an insulator, and heat WILL transfer to ALL of the copper before it ever makes it to the water. Touch any water block, chances are every part of it is going to be hot, metal transfers heat 10x better than water does, none the less acrylic.
If you had two identical blocks, one with a copper top, and one with an acrylic. No one could argue that the the acrylic would be cooler running. However the question is how much heat transfers to the top of the block. My answer would be to touch your heatsink, I would argue that its just about the same temperature all over, you can't just heat up part of a piece of metal. Try sticking a blow torch to the bottom for a second, and touch the top! That would be drastic for you.
http://www.procooling.com/reviews/html/waterblock_roundup_part1-1_2_0.shtml
Notice there are already some plastic topped blocks on the market... they just can't compete with copper thermally...
If you want a good use for acrylic, check out the Obsidian Water God thread, now that is a DAMN nice use of acrylic... So beautiful, I wish I had the $$ to make one of those!
http://forum.oc-forums.com/vb/showthread.php?s=&threadid=75897
I'll take the copper top thank you. Bill
