Question for the group. I have a pair of Bykski DDC pumps (B-PMD3-COV) running together under an Alphacool top. MSI Godlike MB. Each one hooked up to 4 pin Molex and each one to a separate 3 pin MB fan header. BIOS set to DC. No matter what I do to voltage settings in BIOS (or Dragon Center), both pumps just run at 3268 - 3300 RPM. Even if I disconnect the fan headers, and just have power (Molex) there is no discernible RPM difference (should be 100%). Stated max RPM is 5000RPM, so I believe I should be able to get at least 4000-4500. Single pump on single molex from PSU behaves the same way.
