Veeam is great IF it is used as a replacement for windows' built-in system restore feature. I have discovered however that after reinstalling windows clean (erasing the original hd), veeam's bootable flash image complained about a missing dll and therefore was essentially worthless in restoring my original working environment. And this was with it's latest version.
Actually it was simply a reinstall of the original windows os disk. It can in session, restore files and folders, and if you bork your running config somehow and want to fix it, it works excellent. I would recommend it for running windows installs ONLY, even if, or more precisely, they can't boot. But sadly when I simply wanted to abort the new windows 7 install and go back to my fully configured one, it couldn't simply rewrite the image of the previous install and let me move on with my life. From now on clonezilla will be the only way I backup a working OS disk. It is boot image only so it absolutely works with bare drives and doesn't care what the OS is or was beforehand. Veeam is totally free but for above mentioned reasons I will no longer be using it. Also I was able to update to the latest version of Veeam on my desktop, but no matter what I tried on my win7 pro tablet it would not let me update and I am stuck using an older version. Clonezilla will never have these problems whatsoever but you must reboot to backup or restore which is why I was running veeam in the first place as it lets you simply create a task that runs automatic and you never have to shutdown.
With my nas I learned that it will only let you create a raid if you initialize at least 2 (empty) drives as a pair in at once. Once you have a raid1 configured then you can add to it easily. I have to buy another 6tb wd red in order to create a raid1 with my first 2 just so I don't lose all the data I bought the nas for to begin with. Right now they are basically just copies of one another.
The other thing that's weird about the nas is that once you install something it somehow is not uninstallable only disableable. Worse yet, after disabling chrome I found it runs at boot and is listed in the shutdown processes as if I had been using it. In fact, anything you install, even if you haven't opened it, is listed in the process shutting down list when you shutdown. I do not like that at all. Probably all a part of the nas's vm OS environment, but it takes a lot of time for it to shutdown 37 processes. Once I get the two 960evo's I will pull all the drives and start over with just the 960's as a raid1, then add the pci-e 970evo's as cache, then reintroduce one 6tb red, leaving the other in my desktop because it will take three of them just to create a raid1 on the nas without losing all my stuff. In other words if you are not actually going to use it don't install it. Chrome will never be installed again.
Plus I need more memory if I want to run any containers or vm's. So the nas is cute but not very functional yet. Once I get everything raided and have more memory, then I can really start using it with qtier and over provisioning of the ssd's. The nas is very powerful but requires more than just a single hd to be functional. I should really add that the nas will give you alerts if for any reason a drive is failing and makes it easy to replace it. Now if I could just get those 960's.
