g0dM@n said:Well, whatever you do... TAKE YOUR TIME. If you have questions, then post them in there, but make sure you don't ask more than a few questions in one post. I've realized that when I do that only one gets answered, and it's not enough to help...
SirSpawn said:Since this is the guide I thought I would this here.
On the board it has a power connection for the 24 pin which obviously you would connect. It also has a molex and a floppy power connection on it, should those be connected as well?
By the way I have an OCZ Powerstream 520.
g0dM@n said:They ARE there for a reason!!
Hey, Zebbo, CINCO DE MAYO??? Wanna go out drinkin'?
Not necessarily... I think it depends on when you bought your board. If you bought one recently or are planning on buying a new one them I'm sure it will, though.IrishAssassin said:Just a question, would the new cores POST on the Ultra-D without a bios flash ?
g0dM@n said:Not necessarily... I think it depends on when you bought your board. If you bought one recently or are planning on buying a new one them I'm sure it will, though.
