I wouldn't bother modifying the IHS. The reason this could/would/should hopefully work better is because you're removing something thats in the way of thermal transfer. The problem with this method is that you may not get enough turbulence.
One idea I wanted to try, was to make a jet block by putting an insert with holes (think shower head) into the input barb and try hitting the IHS with high speed streams of water. Hopefully something like this would reduce the laminar flow of the water across the IHS.
The only way to know for sure is to try it... or get someone in here with access to scientific software .
