i've only got one 512 meg double sided ddr stick, and it's in slot 1 (closest to cpu)
i noticed that a bunch of hot air from teh heatsink on the cpu is hitting one sdie of the memory... which probably isn't optimal
if i put it into slot 3 or 4, ie further from cpu, will i notice a difference in performance/oc'ability?
i know it's hard to ask for a definitive answer since all systems are different... but just curious for people's experiences
i've searched through the forums... someone said slots 1/3 are good, 2/4 are bad... someone else said they've got one stick in slot 4 and it's great... etc
i suppose i should just go try it myself too
btw i have an abit kx7-333
thanks!
thanks!
