Edit: full timeline here: http://stk.fps-city.com/forum/viewtopic.php?p=27949
I did it..
toughest part was pushing the darn tubing onto the barbs.... cut myself doing it. man that stuff goes on hard!
anyway.. i figured the less connections that were actually in my computer the less the odds that fluid leaks inside..
so just the pump and water block(obviously) are in the comp..
I decided to install the Res on the outside of the case so.. i can refill it easier and one less thing to leak inside..
I found some PVC grommets for a GM that did the trick.. angled the tubing.. you can see in pics..
once i'm confident this will never leak i'll zip-tie all my wires and make it prettier.. but here is my first
so laugh at the newb but i like it.. and my processor dropped 30c!
I did it..
