Hi guyz!
I've got my duron running at [email protected], at 1.85v, on the Asus A7V KT133 mobo. The idle Temp at 47c(crappy chrome orb). It seems to be pretty stable at these settings. Any ideas as to bring the temp down (other than a better hsf)? Should i change some of the settings or leave it as is? I know the KT133 is limited as to the fsb speed. I have 2 fans mounted in a plexi-glass siding(which i did...rather than cutting the original siding of the case.
Duron [email protected][email protected]
Asus A7V KT133 mobo rev 1.02
Bios ver. 1007
256mb Infineon ram PC133/Cas3
Hercules 3D Prophet ll geforce2
SB PCI 128
30gb WD hd ATA100
Bios ver. 1007
SB PCI 128
30gb WD hd ATA100
