noxipoo said:its not even really out yet, i'll worry about it when its everywhere and I need to upgrade. Prob 2-3 more years for ATX
jamesavery22 said:
By the looks of it, it will never be out. Unless Intel puts some real pressure on manufacturers its not going to happen. They all see BTX as nonsense.
As for ATX going away Im sure there will be some new form factor at some point in the future. But not until there is a substantially better design and besides the G5 case I have seen none. Course you could get the functionality of a G5 case with an ATX mobo, just need to mount stuff in the case differently.
MoreGooder said:I'm glad to see that others are just as concerned as I am about BTX. It's bad enough that PCI Express is coming down the pike, which will require a new mobo. If PCI Express is only available in BTX style mobos, then you can add a new case to your budget.
I just hope AMD doesn't jump on this band waggon.
To make matters even more interesting, Intel is hinting that they've solved the extreme heat issues for the upcoming 775 socket. I read that on Inquirer.com. So, what then would be the point of BTX? Just to frustrate us?
Honestly, I wouldn't have any problems switching eventually to BTX if they didn't swap the motherboard tray to the other side of the case. The only reason I can think of for this radical change is that the graphics card industry demanded it so that they didn't have to do major changes to their boards. The GPU stays on the same side for them, but since the mobo is flipped for BTX the gpu faces up rather than down. Or perhaps the graphics board manufactures told Intel to take a long walk off a short peer and thus Intel hand no choice but to push the mobo swap onto the mobo and case manufactures.
FIZZ3 said:
Why nonsense? Do you have a link to show this manufacturer position?
Link to xbit source page
Foxconn seems to be the only mainboard maker besides Intel who has BTX mainboards and even chassis. No other manufacturers cope with BTX today; to tell you the truth, even Foxconn does not believe the BTX standard will ever become seriously popular
jamesavery22 said:
nonsense??
Copied from my first post:
FIZZ3 said:
Not "nonsense", but "why nonsense?" -it was a question.
I must have missed your link to the xbit page in your first post. However, I don't put much faith in what mr. shilov says about this. The tune there always seems to be that newer is NOT better and that better, but more expensive stuff is NOT worth the money. I think he has a personal bias there.
I was hoping there would be more solid sources pertaining the unwillingness of mobo makers to switch to BTX.
