- Feb 20, 2005
- Dubai - UAE
Hi Guys,
I’ve Just upgraded my rig with 3 new EVGA 770 SC (ACX Version) cards and I’m having some serious issues with high temperatures (overheating using stock air-cooling – Goes above 90 c’s).
I managed with the help of some of the great guys here in this forum to fix the heat issues temporarily. You can view the thread from here:
EVGA 770 SC 3 X Way Sli overheating issues
Now, I’ve decided (after getting a good wake-up call from the guys here) that it’s time to invest in water-cooling and I’m looking for a permanent and very reliable solution by installing GPU loop for the 3 cards.
I’m a heavy gamer and do tones of rendering as well. Furthermore, I upgrade my graphic cards every generation or so (depending on the performance boost .. etc) so in average I won’t keep the cards for more than 12-18 months.
I have read a lot about water-cooling (including the awesome guide on this forum) but never had the time/nor/the nerves to do it.
I would appreciate it if you can advise on which parts/brands do I need to get to make this work. Please note that I live in Dubai and we don’t have access to that many water cooling retailers here. I usually order everything from frozencpu.com as it’s one of the few sites that directly ships to Dubai.
My budget is fixed at $ 800 for this project and I won’t be doing the CPU or anything else (I’m happy with push-pull H100i setup that I have)
I’m installing the radiator/radiators in the lower part of the case after removing the HDD bays.
So Far, I considering the following parts, but I really need/appreciate your input :
GPU Blocks:
3 X EK Geforce GTX 770 VGA Liquid Cooling Block - Acetal + Nickel (EK-FC770 GTX - Acetal+Nickel)
GPU Bridges:
Again I have no Idea, on the optimal layout and wot parts/brands/quantities do I need ... HELP plz : )
Reservoir:
1X EK-MultiOption RES X3 250 - Liquid Cooling Reservoir (6 Total Ports)
but I’m afraid the 250 is out of stock, would the 150 one do ? for the GRP loop or do I need the 250 one
1 X EK-MultiOption RES X3 150 - Liquid Cooling Reservoir (6 Total Ports)
Radiator:
Ok guys, once again please help here, would one 240 radiator do the job or do I need 2 of them, and I’m thinking of getting the :
1 X Koolance Dual 120mm Copper High Flow Radiator - 30 FPI - Black (HX-240XC) (No Nozzles)
Fans:
Please recommend some for me and I’m going for a push-pull config. If you said that its ok to go with one 240 radiator only for this loop
Screws:
I have no idea which is the best and how many do I need from each for :
1- Radiator
2- Fans
3- Pump
Pump:
1 X Swiftech MCP655 Variable Speed 12v Water Pump w/ G1/4 Thread Ports (Perfectly Tapped)
Fittings:
I have no idea which is the best and how many do I need from each, this is the least area that I’m Knowledgeable about and your help is much needed here guys (I’m going with ROG Red and Black theme)
Tubing :
• Type
• internal and external diameters
• Length
Coolant:
Please note that I live in Dubai and I’m not sure wot the carriers policy when it comes to shipping coolant liquids internationally, any idea guys if its ok or even allowed, have you tried to order some ?
Furthermore, I just ordered a clear door of the Cosmos II case and I’m going with ROG Red and Black theme, so I’m thinking that a red colour coolant will do that job
Once more, I would like to thank you all for your help on this matter, which is much appreciated
Cheers
DS
